ha! to be fair, I've got a ryet saddle and it's not a bad quality thing. The cheaper £25 full carbon 3d printed ones that is. Only issue is that it was too wide for me. - Bought it before I learned that my cheeks need narrower saddles.
If your GPS data is there, then can't you use the 'correct distance' from the activity popup thing, rather than editing the distance directly? Where the correct elevation and crop options are. I think the only activities you can directly edit the distance to change it are manual entries.Been getting really confused because i've been getting some weird readings on a few recent bike rides. For example this ride only showed 3.4km when it should have been around 20km
<snip>![]()
Not sure why this is only showing 3.8km! | Strava
AI Endurance summary: External stress score: 29 | Stravawww.strava.com
Annoyingly Strava doesn't seem to let you edit the distance anymore.
Thanks for the link!I really shouldn't as need to be saving for the house move but last night as I was adding webpages to that fabled 'bike folder' I was looking at the Bjorn saddle which I think just looks super cool... Turns out Ryett have made their own version of it and it's currently only £65 compared to the real deal being £350...
I shouldn't... but I may...
Other than that, download the original then use something like gotoes to edit/correct/fix it. Gotoes is one of the few 'free' things I've ever actually donated money to. Amazing tools there & saved me lots of pain through the years!
How wide and if you're not using it wanna shift it? I'm one of these people with a legit fat arse (as proven by an expert) who needs wider saddlesha! to be fair, I've got a ryet saddle and it's not a bad quality thing. The cheaper £25 full carbon 3d printed ones that is. Only issue is that it was too wide for me. - Bought it before I learned that my cheeks need narrower saddles.
How wide and if you're not using it wanna shift it? I'm one of these people with a legit fat arse (as proven by an expert) who needs wider saddles![]()
Eurgh that is a pretty hideous view!Think they're 144mm assuming it's the same as @Junglist and I have
I've been looking at the Ergon range of saddles. I've recently bought their grips for my hardtail which i'm turning into a hideous franken-endurance/ultra focused bike. Those with a sensitive stomach look away now. Their saddles seem very highly rated for long duration rides.
Sent you a pm mateit's 150mm
one of these https://www.aliexpress.com/item/1005007725422790.html?spm=a2g0o.productlist.main.5.32fdyeSOyeSOeg&algo_pvid=90a3f832-b099-4861-9a34-8d164a935093&algo_exp_id=90a3f832-b099-4861-9a34-8d164a935093-2&pdp_ext_f={"order":"3","eval":"1"}&pdp_npi=4@dis!GBP!85.90!44.69!!!754.83!392.73!@210390c917391965637261394ec404!12000041993931707!sea!UK!0!ABX&curPageLogUid=zk9uusLMavBM&utparam-url=scene:search|query_from:
paid £35 for it by the looks of it, happy to post it your way for say £20 inc? it's white colour tho.
Eurgh that is a pretty hideous view!![]()
Ah, 144mm wide isn't enough for me. I changed from the standard Powers 143mm to the wider 155mm
I was tempted to report that post. How on earth will that be comfortable?![]()
you can do it with komoot, just export gpx file, import it into komoot and then export out of there into strava as a route.. or use it straight from komoot - I use it often to plan routes and sync to my garmin.Not that i can see. I can add waypoints or set an end point, but that just sends me from the current end point to where i want.
