- 6 Sep 2016
Haha not sure... I've watched Harry Potter recently and been watching Squid Game 2 at the moment. Now I'm intrigued
I know! It's a shame most of it is hidden by the other componentsthats actually a very nice looking board.
Nice build, how are the cpu temps with the Noctua cooler?
Thank for the information,Hi there - yes it’s absolutely fine / great. For context this is a cool(ish) 8 core CPU and the computer is used for gaming. In this setup / purpose, there are no scenarios where the CPU overheats or throttles.
The new AMD chips are designed to work in hot temps. Regardless, in gaming the CPU can be anywhere from the 50s to low 70s with reasonably low fan noise, which I’d consider to be ‘cool’. The only reason it ever gets ‘hot’ (in the 70s) during gaming is because the GPU is heating up the case and I prefer low fan noise over icy temps. If I had GPU and case fans higher, CPU temps would be lower. With that said, it’s probably worth mentioning that the games I’m playing are not ones that are notorious for thrashing the CPU; games that are heavy on the CPU may get hotter temps.
The CPU can boost up into the 80s when doing an a hard all-core workload such as a synthetic benchmark (cinebench) but it will do this immediately and there is absolutely nothing that any other cooler would do to stop it behaving this way.
In short, it’s working really well
If you were doing long, heavy production workloads then arguably you’d want an AIO set-up… but then I’d question why you had a 9800X3D, since you’d be better off with another CPU!
Do be careful with installation though as per my posts earlier in the thread as I messed it up initially by accidentally moving the thermal paste guard on top of the CPU… causing very high temps. That was me being clumsy-ish but it’s a pretty easy mistake to make if you try to ‘wiggle’ the heatsink mid-installation.
I'll mainly be gaming I wont be doing any heavy production anytime soon. I do very much like the idea of an AIO and like the look of them but for some reason a good air cooler seems great for longevity.
Don't know if it helps at all but I've been running an Arctic Liquid Freezer II 240mm (from OCUK, obvs) since - and I had to look this up - the beginning of December 2020. That's on a 16-core Xeon in a ventilated cupboard that peaks at 34°C ambient temperature in the summer. Maybe it's an outlier but I can't say I can complain about the lifespan.for some reason a good air cooler seems great for longevity.
Can’t beat an air cooled setup for aesthetics and simplicity IMO. I have a 9800x3d and a Noctua u12a cooler in my PC.
Noctual are beautiful. Who doesn't want a full passion project themed after them?can't get away with those noctua colours - otherwise nice!![]()
