There are obviously pros and cons to both triples and VR. I prefer triples myself, reasons including a bigger fov which is an advantage for having things in your peripheral view, also I don't find VR headsets comfortable at all, especially when doing longer sessions of multiple hours. Triples also give the freedom of being able to see my streamdeck buttons, dashboard screen and easily being able to grab my drink etc. I also don't find the clarity on VR all that amazing and find it a bit of a faff in general.
It helps that the 9800X3D is an absolute gaming beast too! Going from 3900X to 5800X3D was a significant upgrade for me. I think it should see me through a few years before needing an upgrade.
Do I have disposable cash burning a hole in my pocket ?Do I need to change my fanatec gear (podium dd and v3 pedals with v1 handbrake)?: No
Do I fancy seeing how much greener the grass is on the other side: Not sure.
I race in mainly VR, but also have a 34" UW monitor..... is that what you have there? 1 x 34" UW and 2 x 27"
How hard is it to get games running with 2 different size monitors? do you think it's better than 3 x 27" sorry for the barrage of questions lol
ah ok thanks! I only play Iracing really, but it kinda looks better having a big front screen and 2 smaller sides! but I guess the norm is 3 monitors the same so its all setup for that.Yes, I have the one 34" and two 27" screens. The reason behind it is that I started off with the 34" UW, then decided later on I wanted triples.
Assetto Corsa works perfectly with it, in content manager you can manually adjust the position of where the triple monitor corrections are. ACC works using an app called SRWE to manually change the resolution of a running app, a bit of a pain as it has to be done every time I launch the game, and you sacrifice the ability to have bezel corrections. LMU works by editing the config file to set a custom resolution and has worked superbly, but again you sacrifice being able to use bezel correction.
My plan is to grab another 27" and have matching screens fairly soon to be honest. I'll miss the UW in the middle, but it's going to be the best option moving forward to make things work nicely. I'm thinking of using the 34" as my main desktop monitor and move my old 27" Dell onto the rig as a 4th monitor above the middle one.
See I don't have space for triples so gone for a samsung g9 neo. Nice middle ground (5120x1440, so like having 2 27") and means I can play games without having to mess around with config files and whatnotah ok thanks! I only play Iracing really, but it kinda looks better having a big front screen and 2 smaller sides! but I guess the norm is 3 monitors the same so its all setup for that.
Where is the 499p model from?
I was at Le Mans in 2023 when the 51 won and I got this print for my sim room, I’d love a model to go with it.
be nice if they made 1 monitor that was like triple'sSee I don't have space for triples so gone for a samsung g9 neo. Nice middle ground (5120x1440, so like having 2 27") and means I can play games without having to mess around with config files and whatnot
Is that a 49 or a 57?Over the last couple of weeks (since missing out on Daytona 500 due to iRacing licence requirements) I've been getting really into the oval side of the game. The Hyper P1 is an amazing wheel but not ideal for speedway racing so I considered many options. In the end, I settled on buying a Sabelt steering wheel, mechanical QR for my wheelbase and Moza SGP sequential shifter. The setup is so so good (imo of course) but the lack of button box/wheel buttons is a negative. The shifter has 2 buttons on it which I use for "Next black box" and "Open mic" but I'm considering options for either a streamdeck or button box I can mount to the cockpit.
How the rig sits currently:![]()
Its the 49". If I was to buy again though I'd probably got for triples. I'm always on the look out for someone selling triples on the sim hardware selling pages but they always seem to be miles awayIs that a 49 or a 57?
Its the 49". If I was to buy again though I'd probably got for triples. I'm always on the look out for someone selling triples on the sim hardware selling pages but they always seem to be miles away![]()
