Listening to Buildzoid, it seems like the general consensus is that the sense pin changes on the new connectors basically achieve nothing. The issue is that the GPUs can't load balance or sense current irregularities. 3090tis had the regular old 12VHPWR connectors, drew a lot of power and they didn't have issues because they were load balanced properly. 40 and 50 series cards (at least the high power 90 series) are inherently faulty.
I think the point buildzoid was making is that there is absolutely nothing that can be done after a conductivity problem occurs without major revisions to the design.
We need to distinguish between two things:
1) The possibility of there being a conductivity error caused by misaligned pins etc. This is what the H++ standard seeks to address. Lower chance of issues because everything should be seated correctly. It IS better.
2) What happens when there IS a conductivity issue. As buildzoid notes, the overall design standard is poor because there is little that can be done. The ASUS / Zotac type of fix of signalling to the user that something is wrong is a mitigation, but it doesn’t change the inherent problems caused by of shunting so much watts / current through tiny wires - when things go wrong, then go wrong in a big way.
, image removed.
