*** The AMD RDNA 4 Rumour Mill ***
Using the settings in that vid:
7800XT MBA card no driver tweaks.
Core Ultra 285k (Intel baseline profile) and with no info on ram speeds and timings in the Chinese leak, I used a 6400 XMP profile which is what reviewers were given as baseline testing for Core Ultra CPU's.
Win11 24H2 Intel PR5 fixes and bios updates in place.
Now comparing this to the original Chinese leak on X and using a 7800XT to compare with (at the supposed same settings) , looks like the 9070XT is a little monster considering the amount of shaders it actually has.
All boils down to street prices now, not imaginary MSRP's.
I ran this benchmark today on a heavily overclocked and undervolted 7800XT mba at 1080p and FSR Quality and Frame gen on with Ultra settings and RT off (are those the alleged settings on the leaked 9070xt benchmark?)
Radeon drivers 25.2.1
7800XT
Overclock settings
Min core 2750
Max core 2950
998mv voltage PL15%
Vram Fast timings
2578mhz
Fans at 75%
Usually get a GT1 Timespy extreme of 67fps
And a Timespy graphics score of 22176.
Got a score of 29610 and average FPS of 173.98
So that makes mine about 21% behind the alleged 9070xt so not bad really! Not sure it’s worth me upgrading to a 9070xt after all?
Thoughts anyone?
7800XT
Overclock settings
Min core 2750
Max core 2950
998mv voltage PL15%
Vram Fast timings
2578mhz
Fans at 75%
Thoughts anyone?
That's just one test if it's tested right , need to see on over number of different games and still RT and upscaling to add to that
Also what drivers are being used.
All a bunch of speculation and as it's not long to wait for some more credible information.
May as well wait...
It's a bit of give and take.
As of 2024 Normies don't need a GPU card, you can game nicely off a CPU or Nvidia streaming.
well if you live in a city or large town , most people are still on 30mbs tops download speeds or below
where I live you have about 5 streets on 1000mbs the rest they cant figure out how to rewire everything without major roadworks
7800XT
Overclock settings
Min core 2750
Max core 2950
998mv voltage PL15%
Vram Fast timings
2578mhz
Fans at 75%
Thoughts anyone?
could you do us a favour, scroll back and run the black ops 6 benchmark pls. at stock.
Thoughts anyone?
I would be if you value the better AI upscaling, RT and any other feature the old gen doesn't have. If they don't mean much then stick with it till UDNA.
Does anyone know which model this one is;
I love the Powercolour ones as well. The Nitro dosnt look no where near as good this gen, with that mesh. :(
XFX EVGA Mercury RX 9070 XT OC Gaming RGB 16 GB
There is also a white one in the same Model.
Budget for 799 for the black and 899 for the white one.
