I've knocked up a design for my new roof and tried to work out where I could fit panels. I've left ~400mm to the roof edges, but most of these roofs are new so I'll likely be going for in-roof panels, which hopefully means I can go closer to the edges (so I might be able to squeeze a few more on).
As you can see, there's a lot of different orientations/layouts involved, so I don't thing s classic string inverter is an option. I want to pair these with batteries, so I believe my options are (and correct me if I'm wrong) to go for a hybrid inverter, or optimisers on each panel. The latter bumps up the cost considerably, but the former I believe means I'm restricted to a max 3 strings as the max number of MPPT's on hybrid inverters seems to be 3.
If that's true, which 3 strings would you pick from the following options? The blue wall is North facing, the yellow wall is South facing.
I was thinking 1 string for the east facing main roof (14 panels if I can include the 2 on the extension in the string), 1 string for the south facing main roof (6 panels), and then it's a toss up between 7 panels on the East facing lower roof, vs 6 panels on the North facing main roof. The former would get more direct sunlight, but would be shaded by the house for half of the day. It might not be too aesthetically pleasing either.
Any comments/suggestions?
