- 22 Feb 2014
Recently poured self leveling on bathroom floor and it is cracking. will I be ok to lay tiles on this or will it need to come up ?
Floor is
18mm plywood
6mm insulated cement board
primed, then lay electric UF heating mat
6mm(ish) of self leveling
at this stage some of the heating elements had come unstuck and risen to the top of the screed.
So i dug out the worts affected areas and secured them to the floor then covered with tile adhesive
then primed again and repoured 3mm of self levelling over the top of the existing
now it is cracking. see pictures below
Floor is
18mm plywood
