Why wouldn't it be?So 7900xtx still a good card for the foreseeable?
What manufacturers are good to go to for AMD cards? I've been team green for a long while, but will likely try to pick up a 9070XT. Need it to be as quiet as possible (whilst as performant as possible of course).
Sapphire, PowerColor and XFX are all generally really solid for AMD cards, as you'd expect from exclusive partners. Personally, I wouldn't look outside of those three, but ASRock would probably be next in line. I'd avoid Asus and Gigabyte entirely. They've historically treated AMD cards as afterthoughts and put little care into their design or construction. MSI the same, but they've already jumped ship.What manufacturers are good to go to for AMD cards? I've been team green for a long while, but will likely try to pick up a 9070XT. Need it to be as quiet as possible (whilst as performant as possible of course).
Because I'm driving myself simple trying to figure out if I should return it and try for something newer (50 series or 9070xt).Why wouldn't it be?
Yes, of course the whole thing is a conspiracy. use your own time to dig through HUB's back catalogue to be part of said conspiracy.
Unless you can afford a 5090 then any other 50xx card would seem very much a pointless sidegrade.Because I'm driving myself simple trying to figure out if I should return it and try for something newer (50 series or 9070xt).
Can't see it "being useless" even in 5 years. Raytracing uptake has been so slow that even in 5 years time I doubt it will be embraced everywhere. Even if you did change, then unless you went for a 4090 or 5090, anything else is going to be a VRAM reduction, which may be more of a limiting factor in a few years time than your "early gen" raytracing tech.It's a fantastic card right now for 4k high refresh but I'm worried more and more stuff will have baked in ray tracing and it will be useless within a year or two, which would also lead to terrible resale value.
Hmm, would a 7900 xtx be a decent pick up now then rather than playing the waiting game for rdna4 cards?Unless you can afford a 5090 then any other 50xx card would seem very much a pointless sidegrade.
9070xt is likely to be a downgrade for the most part.
They’re not cheap anymore btw. (Circa £900)Hmm, would a 7900 xtx be a decent pick up now then rather than playing the waiting game for rdna4 cards?
One of my goals is displayport 2.1.
The 7900 XTX is going out of stock faster than I have ever seen. I think the RX 9070 XT will perform at the same, or in excess of the 7900 XTX.Hmm, would a 7900 xtx be a decent pick up now then rather than playing the waiting game for rdna4 cards?
Not in 90% of the country with crap internet and you still get really bad latency on anything competitive5k PC Gaming masterace has been overtaken by PC Gaming streamers with no kit and a £15 keyboard and mouse.
There are only a couple of GPUs with more VRAM and only a handful of GPUs that can beat it. So in that respect, I'd say it's great and would keep one for many years to come. Obviously depends on how much folks care about raytracing, as much as 9070XT will improve on that front, I don't think folks will be buying them for the ray-tracing performance, especially as most games still don't use it or have it as an option that drains FPS, with little gain in visual quality.So 7900xtx still a good card for the foreseeable?
I like their better naming scheme, the existing names are so confusing as to what's what in the lineup. That quicksilver looks nice and with only 2x8pins. If it has 0 rpm mode and compares well to the Sapphire Pulse, it could be a decent alternative option.![]()
XFX Radeon RX 9070 non-XT cards spotted on Amazon, boost up to 2.7 GHz - VideoCardz.com
XFX Radeon RX 9070 SWIFT and QUICK SILVER pictured Thanks to the leak from Amazon, we have the first look at official images Radeon RX 9070 from XFX, and no, these are not XT variants. Some of our readers were concerned that the focus on RDNA4 seems to be on the 9070 XT variant. However, […]videocardz.com
Traditionally the $400 price point gave previous gen 80 performance. The 7800XT was $500 and matched the previous gen 3080, that wasn’t really considered great value so if AMD now want to charge $700+ for last gen 80 performance and that’s supposedly going after market share then that’ll be a major fail.We all know they won’t come in at £550 for the 9070XT and I have a nagging fear they’re going to charge £699 or even £799 for the msrp models.
