Hostile_18
Hostile_18
2pm.What time are reviews out today?
Sorry but as someone that spent a fair amount of time looking for 2 slot cards, 52mm is not 2 slot. ~40mm is 2 slot. It got quite annoying looking for 2 slot cards...
Do we know why Asus have gone with 3x 8 pin connectors on both of their cards vs. Sapphire Pulse having 2x 8 pins (on the Pulse model)? Assuming they're both going to very similar in performance.
My thoughts exactly.It hasn't but the prices looked very specific.
My be quiet 1000w PSU came with only daisy chain pcie cables, ran a 7900xtx on them (3x8pin) and it pulled 460w.Better distribution of load ?
Some of the better PSUs handle 600W off 2x8pins with decent cables perfectly fine
For those with inferior cables and or with cables wired with 6 pins then 3x8pin would be better distribution
Also remember never to use those y-cables running off a single 8 pin - you will definitely be limited to 300W which is a lot of load on a single channel if the y-cable is rubbish quality
Yeah, that makes sense, thank you. I guess a bit like when we see B-series motherboards occasionally have 2x 8 PIN connectors!Better distribution of load ?
100%, Sapphire's cooling has always been fantastic too. My 7900XT Pulse never goes above 70 deg at full beans.the three slot pure will have better cooling than the 2.45 slot hellhound?
you're not getting one so what does it matter!Do we think MSRP will be hit consistently by the Summer?
Impossible to say. I wouldn't take anything for granted in this market. I'd buy now if you can afford to.Do we think MSRP will be hit consistently by the Summer?
One thing I appreciate nvidia doing is making a number of partner cards to fit a specific smaller form factor. I do hope that gets further adoptionSorry but as someone that spent a fair amount of time looking for 2 slot cards, 52mm is not 2 slot. ~40mm is 2 slot. It got quite annoying looking for 2 slot cards...
