I'd be quite interested to try out the metal keycaps
Had a button issue with the Edge, been waiting over a week for the supplier to send out a replacement. RubbishBlack Dualsense Edge arrived today. Really happy with this combination(Wooting 60HE+ and Razer Viper 3 Pro)
Ah that's really frustrating, what's the issue? I've had the original release Edge since it launched 2 years ago now and outside of the rubber grip starting to come loose it's been really good. I swapped my right and left sticks when I started getting minor drift in the right stick a few months ago and I've got a spare module ready to go if needed as well.Had a button issue with the Edge, been waiting over a week for the supplier to send out a replacement. Rubbish
The X button would stick down a little like it was catching and then make a weird squeaking noise. Sent it back and got another one direct from Sony instead and the new one has the same issue. Never had it with the white edge though. Still works, just annoyingAh that's really frustrating, what's the issue? I've had the original release Edge since it launched 2 years ago now and outside of the rubber grip starting to come loose it's been really good. I swapped my right and left sticks when I started getting minor drift in the right stick a few months ago and I've got a spare module ready to go if needed as well.
Read something similar about the sticky buttons on Reddit for the newer black version, I wonder if they've got a bit of a defect in production. Could you take the faceplate off and see what it's catching on?The X button would stick down a little like it was catching and then make a weird squeaking noise. Sent it back and got another one direct from Sony instead and the new one has the same issue. Never had it with the white edge though. Still works, just annoying
Oh really? That's interesting. Is it easy to take the faceplate off? Never looked into doing it, scares me haha!Read something similar about the sticky buttons on Reddit for the newer black version, I wonder if they've got a bit of a defect in production. Could you take the faceplate off and see what it's catching on?
Nah, it's annoyingly not as simple on the Edge as it is on a regular controller. You've basically got to do a full disassemble - including removing the screws.Oh really? That's interesting. Is it easy to take the faceplate off? Never looked into doing it, scares me haha!
If it continues I think I'm definitely going to have to do it or it's going back. Really want the black one as well as it matches everything else. First world problems eh!Nah, it's annoyingly not as simple on the Edge as it is on a regular controller. You've basically got to do a full disassemble - including removing the screws.
It might be worth doing if it's properly annoying though - and if you're relatively handy with these sorts of things you should be fine! I took my original Edge apart when the grips started peeling off as it started to really annoy me when I caught my hand on it and it wasn't too much fuss, there's a lot of YouTube guides showing how to take it apart without ruining anything!
