Its a replacement for the 7800XT, it was never going to be a good upgrade for anything > that.Following seeing reviews I'm struggling to see how a 9070XT is a justifying upgrade over my 7900XT.
free queue entry if you bought a £500 9800X3D?It is only a 60 premium when the pulse goes up to 630.
On a side note I wish there was a private queue for us forum members on these launches XD
Indeed. It looks like a great buy just my inner nerd was hoping for an upgradeIts a replacement for the 7800XT, it was never going to be a good upgrade for anything > that.
Its a mid range GPU, its not meant for that.
I think its an improvement over the previous generation with a $100 price increase and the previous generation also had a $100 price increase.Indeed. It looks like a great buy just my inner nerd was hoping for an upgrade.
I've been rocking my 2080ti for the last 3+ years, the 9070xt looks like a viable upgrade to this without sending the wife crazy!I also don't get why people would want to upgrade gen to gen anyway. Even more when it's a mid range to mid range.
I looked on my OCUK account last night as I was saving my address to try and get an order through later. My last card i bought in 2018...if we think 2 gens time will be 2029/2030 I can literally by buying 1 GPU a decade upgrading every gen is madness to me especially in the current climate.
For some people, this is their main hobby. Not necessarily gaming but just being involved/invested in latest tech and enjoying that part to it.I also don't get why people would want to upgrade gen to gen anyway. Even more when it's a mid range to mid range.
The yearly amount I spend on PC parts is nothing compared to what my best mate spends on golf...!
Well the drawback is the performance hit, but in principle you could run lower quality to make back the performance with better overall image quality than with FSR 3.If this is true and there are no drawbacks that would be awesome.
Yes, to that point, Tim@HWUB commented he thought the FSR4 demo he saw was running Quality mode. Then found out it was running performance mode (!)...so its a decent step up for sure, especially in motion.
I'm thinking about switching from Nvidia and getting a 9070 XT but have a question. On Nvidia GPUs if you set low latency mode to ultra, Vsync on and enable G-sync, then it will automatically cap the frame rate slightly below your monitor's refresh rate and eliminate tearing without increasing latency. This is better than using an in-game frame rate limiter which can still have tearing unless you set the frame rate limit much lower. Does AMD have an equivalent feature?
AMD have Anti-Lag and Anti-Lag2, the latter requires in-game support.Don't know about all of that but you can set V-Sync and cap the frame rates as per game basis or globally in the drivers. I don't know what "Ultra low latency mode" is.
Cool and Quiet. Been there for years. Mapped to hotkey and appplied on all those games that want to draw 700w over 1000fps in the damn menus.I'm thinking about switching from Nvidia and getting a 9070 XT but have a question. On Nvidia GPUs if you set low latency mode to ultra, Vsync on and enable G-sync, then it will automatically cap the frame rate slightly below your monitor's refresh rate and eliminate tearing without increasing latency. This is better than using an in-game frame rate limiter which can still have tearing unless you set the frame rate limit much lower. Does AMD have an equivalent feature?
