Ok, I've delayed, I've diverted (see above
) and I've procrastinated. Perhaps it's time for just a little progress before I procrastinate some more!
So one of the things that's bothered me is that I put all the effort in and then once it's below the desk, because of the orientation after a room rearrangement, with the windows facing away from me, I can't see any of it. I can't really reorganise it to the other side of me without ending up with a storage pile at my feet and I can't put it on the desk without losing my mini bookcase and modular tool holder (this bag for networking jobs, this bag for some future use, another bag for other future use and no bags the rest of the time - it's tidy, sue me!
). What I need therefore is a case that is inverted but still has the PSU at the bottom (where it ought to live because of weight balance - old-school PCs were just wrong on that front....although, to be fair, we're talking 300W PSUs in those days). There aren't that many options but I was drawn to the Lian Li O11 Evo. Ooh, there's an XL version that you can remove the side pillar....but I don't need the extra rad room if my rad is (and must be!) external. I finally settled on the
O11 EVO RGB (from OCUK, obvs) as it was between the two in size and still had the removable corner pillar as well as the best of both. I'm thinking that the rad can be completely external with QDCs so it can stay under the desk if I need to move the case for maintenance. What I want is lighter really.
So case arrived and....mission failure already. This is NOT going to end up light!
Ah well, on we go.
I'm not sure currently whether to mount the GPU traditional,
vertical or
upright (goes where the side fans are on the motherboard tray). There's pros and cons to all options - aren't there always?! If I go tradititional, you don't get to see the waterblock...but it costs nothing extra
If I go vertical, it takes up all the PCIE slots and I'll need to see if I can add a 10 gig network card into the vertical bracket if I add another ribbon cable - not sure it'll work at all, let alone neatly.
If I go upright, the biggest con is that while the bracket is cheap, the required PCIE cable (60cm or 90cm) is £86. I'm also not sure where I'd put the res because that's currently where it goes and sticking it in front of the gpu waterblock would seem like a step forward only to take one backwards.
At this point, I should say that this isn't going to be a here's the case, let's shove all the stuff in it kind of build. I could but I kind of want to push the envelope a bit further each time and I'm thinking that some custom acrylic-work in the form of an overly complicated distro would be a good way to do that. Go big or go home, right?! I also think I'm going to need to swap from RGB to ARGB as this case has strips of that and I think the waterblocks do too, so no point in trying to keep the RGB elements from the old build. That will mean either reworking the res (custom PCB I think this time) or changing up the res entirely.
Since I'm planning to design this rather than just go at it and see what happens, how many drain ports should I go for this time!? Zero was clearly a bad plan, two (because of two sides to the loop) was a pain, maybe it should be three this time for maximum drain speed in the umpteen times history says this will need to be drained!
Right, I'm off to rebuild this case upside down
