- 15 Mar 2010
- Bucks
600 is right on the edge..I would upgrade psu tbh. You should put your parts in partpicker and figure out top end power draw your likely to be very close.I bought Pulse - it uses 2x8pin cables - should I use two separate psu gpu cables or can I use single cable with 8pin split plugs?
Also, do you think 600W psu would be enough or not?
