Cheers! I was looking for that workaround. Tried it and it works.There is a update for msi afterburner which allows the memory to get to 3000 alternatively use GPU Tweak 3 and enabled extended overclocking feature and will allow you to get to +6000 / +3000ab . The voltage bug is fixed with the must recent hotfix driver 572.75 but you do lose a bit of performance on that driver, best for benchmarking is 572.47 but need to use the work around I posted on Overclock.net to get voltage working...
[Official] NVIDIA RTX 5090 Owner's Club
Last Updated: May 23, 2025 Note: This content is licensed under Creative Commons Attribution-NonCommercial-NoDerivatives 4.0 International (CC BY-NC-ND 4.0). You are free to share, copy and redistribute the material in any medium or format under the following terms only: 1) Attribution — You...www.overclock.net
GPU Tweak v1513 seems to allow +3000 on the memory.
