- 5 Nov 2024
- Oxfordshire
These last few days ive been using my computer more than i have done since i built it months ago and the use has been for gaming compared to previous usage being setting it up and doing some video editing at which point i never needed to take any notice of temps nor was the fan being loud and kicking in at high speed a lot.(i assume its that and not my rx 570 which tends to run slightly cooler)
Its the 5900x with an ID cooling single fan tower cooler. according to Msi Afterburner the temps for the cpu have been mid 70s to mind 80s with the power usage going up to around 125w.
Being a 12 core processor, the utilization tends to range from 6% to 60% most the time i think without double checking.
I know every processor varies and the 5900x is a high end chip, but im only playing games long enough to record some decent footage, so within that hour im playing multiple games pushing them the best i can for the hardware.
The noise alone is making me want to change to an AIO, but i can only fit 120mm versions which i dont know will make that much of a difference with that i have described.
