Finally got round to finishing my new build over the weekend what idle temps are you all getting, mines is idling about 45-50c and maxing out at 70c when running Cinebench, I’m using the Lian Li hydroshift AIO is this about normal?
Load temps look ok but idle should be a bit lower. Do your clock speeds drop when at idle?
Can't remember if it's the high performance power plan or something else that keeps the clocks high, even at idle.
