Say no moreSTUDIO DRIVER
Doesn't look that impressive to me for the perf hit![]()
On a 9070XT, happy enough to play through at 1920 with no upscaler - can not stand any of the oil painting smearing with either NVIDIA or AMD GPUs.
1920 res
Upscaler off, render quality High, 25-30fps
Upscaler off, render quality Medium, 30-40fps
Upscaler off, render quality Low, up to 60fps
It's grainy, sure but it's the only peek into the future I'm going to get with this spec PC![]()
That's the issue the image quality is very grainy unless you use a high resolution but even the 5090 only gets 20fps running HL2 RTX at 4k
So really this is a less a videogame and a more a tech demo used to make YouTube videos
Looks like the rtx remix texture streaming system works very well compared to portal rtx. I haven't see my vram go above 13.5gb so far.Is it though?! See my screenshot where 11GB of VRAM is used by the game alone, meaning 18GB VRAM totalYou will be glad to know 12gb vram is enough tooLooks like the rtx remix texture streaming system works very well compared to portal rtx. I haven't see my vram go above 13.5gb so far.
Which means the game will be swapping to system RAM on sub 16GB cards I guess?Is it though?! See my screenshot where 11GB of VRAM is used by the game alone, meaning 18GB VRAM totalWhich means the game will be swapping to system RAM on sub 16GB cards I guess?
Games can and do use more vram if the vram is there and the game/engine is well optimised. I saw this first hand when coming from the 3080 to the 5080, games like silent hill 2 and others played just fine showing 8gb (dedicated), no performance stutters, textures all loading in fine, swap in the 5080... exactly the same experience in terms of textures and frame time performance, however, vram was showing 11/12+gb dedicated vram so you would have expected there to be the vram symptoms in those games with the 3080 but there wasn't i.e. the games scaled depending on what you have. The likes of UE 5, snowdrop engine are extremely good for their vram memory management in the sense that they scale well, also, as shown by multiple review sites now, nvidia handle memory management much better than amd so I am sure they have applied the same kind of optimisation to their remix program, they did make that a key talking point about this version of remix too.
OMG. It actually did crash.
Asked me to update to latest drivers![]()
You should know by now....Games can and do use more vram if the vram is there and the game/engine is well optimised. I saw this first hand when coming from the 3080 to the 5080, games like silent hill 2 and others played just fine showing 8gb (dedicated), no performance stutters, textures all loading in fine, swap in the 5080... exactly the same experience in terms of textures and frame time performance, however, vram was showing 11/12+gb dedicated vram so you would have expected there to be the vram symptoms in those games with the 3080 but there wasn't i.e. the games scaled depending on what you have. The likes of UE 5, snowdrop engine are extremely good for their vram memory management in the sense that they scale well, also, as shown by multiple review sites now, nvidia handle memory management much better than amd so I am sure they have applied the same kind of optimisation to their remix program, they did make that a key talking point about this version of remix too.
Of course, you are very correct for **** optimised games, they will use everything without proper management so gpus with lesser vram will **** the bed e.g. like the last of us on release before it got patched
IIRC, you have some overclock/undervolt profiles? If still crashing, be worthwhile trying stock, game is crashing a lot of folks overclocked/undervolted systems.
That or time for a gpu with more than 12gb![]()
Will try just a power limit in MSIAB instead of using the UV/OC profile as yeah random crashes. I best it still crashes though as it seems game related considering no other game crashes!game is crashing a lot of folks overclocked/undervolted systems.
