- 1 Sep 2013
Installed my nitro+ today. Happy with it as an upgrade from 3080 10gb.
I'm torn between this 1 and the red devil to be honest
It's a super solid cardInstalled my nitro+ today. Happy with it as an upgrade from 3080 10gb.
Which one you getting?Speaking of which, Any of the red devil owners got any pictures of it in their case? I've had a look at all the links on page one but none of the owners have pictures in the case.
I've got a Nitro+ pre-ordered elsewhere. Longer wait but cheaper than launch price by near £20.Which one you getting?
Is that the May delivery £685? I'd have rather have paid £699 and have been using it 2 months.I've got a Nitro+ pre-ordered elsewhere. Longer wait but cheaper than launch price by near £20.
Been eyeing up the red devil since before launch though.
I didn't like the nitro+ when it was that priceIs that the May delivery £685? I'd have rather have paid £699 and have been using it 2 months.
I get about the same. I started out benchmarking at -140mv but quickly realised games were unstable until -70/80mv. Pushing the GPU to the limits with power limit +10%, -70mv, +50 core nets some nicer benchmark results but I quickly ran into diminishing returns. Playing with settings in game, you can go from 240w to 340w and only see a difference of single digits in frames. Makes sense to go the efficiency route combined with a VRR display.How are people with the XT pulse finding undervolts?
Not done loads of messing myself yet, though found that -20% power limit with -100mv will give me better than stock clock speed whilst pulling 240w, seems a decent trade off but it's my first time ever trying this
yeah on ATX boards it sure looks guuuudI'm still not sure I like the use of the new cable and the positioning and all that, but it does give a clean look not having power connectors on this side of the card.
In fairness it only seems to reach up to the radiator, which is probably 27mm thick? (based on those fans being 25mm), so 298mm + 27mm = 325mm.
EDIT: Also, I have that case!
Also the 3 x 8 pin on the powercolor vs the 12VHPWR on the nitro+Kitguru did a comparison of the two and made a video. Basically near identical performance with the exception of aesthetics.
Is that what you measured, because the Corsair website says the max GPU length is 320mm?There is 320mm space after you install the fans and the radiator. As you can see the card is less than 10mm from the fans. If it was actually 298mm it would be more than 20mm from the fans.
