I only moved away from 7 when Steam stopped supporting it. Will do the same with 10.
Theres a windows 10 LTSC version. I was using it for a good while. If you dont need microsft game bar because you dont require the AMD 3d cache gaming driver and you dont use HDR then its great.
You can install the microsoft store if you like. Youll need that if you need the game bar.
There are no adverts and no data mining. Its for corporations and requires a volume license key.
If you pop over to github there are various utilities and scripts to help you with your install.
It's easy to switch between the versions with a simple key change.The IoT LTSC version is supported until 2032 while the standard LTSC only lasts until Jan 2027. Make sure to install the former if you're going to have a play as the latter isn't worth the hassle.![]()
Eh? That's a thing?Yea I'm still on windows 10. I'm also at the end of free upgrades on my licence so if I want to go to windows 11 I'll need to pay.
Eh? That's a thing?
I had Windows for Workgroups 3.11Yup same.
Windows 7 was the best one imo.
And I'm old enough to remember 3.1 or whatever it was.
The fundamental issue is that windows 11’s primary purpose is no longer to provide the customer with a clean, efficient, functional operating system for running their applications.
It’s goal is to push you into Microsoft’s cloud platforms and lock you into their ecosystem so they can milk you for subscriptions forevermore.
Until that changes from what I’ve seen windows is only going downhill from here! The issue being that Google and Apple are just as bad.
Hopefully Steam or Linux can provide an OS a bit more open and streamlined so we’re less dependent on Windows in future.
Ye, I think my licence is Win 7, or possibly early, they only let you upgrade so many times I guess.
Having windows 11 on my new build is like having a virus for an OS. I should have stuck with 10. Even installing it took me over a day because of some really dumb features ( their 'out of the box experience' where you have to use dos to get past the internet driver not recognised hang - it's bloody working, you just used it to download your updates!).
Even just installing new drivers for my new 9070xt has turned into a nightmare threatening to brick my pc.
Win 10 was much easier, you could do things with it and find things. Even on Pro, win 11 hides and greys out options.
Pretty certain it must be earlier, because I've gone 7 -> 8 -> 10 -> 11 without issue. Well, apart from everything about Windows 8 anyway.
Pet Peeve PSA: It's not DOS, that was a type of CLI OS that - outside niche use cases - went the way of the dodo 30 years ago. What you're talking about is command prompt.
