Please don't tempt meBooked in for it's MOT on Monday, then we'll see if I can actually make myself write up an advert to get it sold.
I wire brushed only the third one as it was really bad. Will think about repainting them, won't be doing it myself though. Probably next year. I ride in dry weather anyway.Oven cleaner usually works great on the coating they put on exhausts. If you've wire brushed it you might be down to the metal though, so it'd be a case of either repainting or a continual battle with rust.
There was a 44Teeth video a few years back, where BVG was having an S1000R cleaned, and the chap doing it used some magic spray to clean the pipes up - but they censored what it was.Worked on one 3 of the 4 exhaust headers today on the LH side (other side planned tomorrow). Couple of rounds of Dr. Downpipe and about 40-60 mins of effort and below is the result.
I am satisfied with it for now. Will probably do another round. The Scourer they provided to agitate the dirt was not good at all. I used another tough one that we have from Aldi. Needed to use a steel wire brush on the third pipe, which was the most corroded.
Any other suggestions are welcome to improve their condition. I do understand that they are never going to look pristine.
Before:
After:
For the Harpic trick I think I will have to take the headers out, which I am honestly scared to do.I have tried the old harpic trick though - either way, hose down with lots of clean water after.
I just brushed it on, then rinsed it off with loads of water.... probably wasn't great for the driveway (oh, and environment)For the Harpic trick I think I will have to take the headers out, which I am honestly scared to do.
My exhaust headers appear to be in much worse condition than the ones in the videos. For now I am satisfied, until next time.
Edit: Guess will try this. Looked neat.
Had the 2019 model, the same as you had - gen 2 iirc, this is the next one along their lineup; would have loved the saucy new one in blue/flo green - but they're 17k or somethingDidn't you have one previously?
I've got a full Black widow decat system for that sat in my shed.
I won't filter past dopey women.... or roads on my rightThat's got the fancy TFT dash and looks a million times better.
Please try and stay on this one![]()
