Undervolting is for wimps. Max performance!
(Mine is also pulling fewer volts than would otherwise normally be required for my 3250 MHz core clock)
Haven’t gone above 500W so far so I’m alright with that. Might try and tighten it up and go for more overclock when I’m back home.
Just tried a dirty overclock for the first time +300Mhz core +3000Mhz memory
Compared to my usual undervolt (.895/2827), with the overclock in Steel Nomad the card ran 3 degrees hotter, used on average 70w more power, clock was at 3172Mhz, and Nomad score improved 1.9%.
Tried several games (loading in at the same point) and saw no difference in actual FPS between overclock v undervolt.
