I got 15.3k in Steel Nomad at my settings of +270 on core and +2000 on memory (Gigabyte Xtreme Waterforce) but definitely power limited in this benchmark versus what I typically see in games. Pulls the full 600W from the wall and the card doesn't boost as high as it does when it's not power limited. Minus Cyberpunk which similarly draws loads of power although boosts about 150 MHz more than Steel Nomad.
Try increasing your memory overclock. Loads of headroom there generally. There's a way to allow you to do +3000 MHz which I haven't tried but +2000 MHz has been rock solid for me.
This is my 15.3 steel nomad with the undervolt starting at 0.935. Just to say that you'd be getting way better results than mine with an undervolt, instead of wasting voltage and power using the traditional method.
On paper, your card is much better than my Vanguard, so I'm sure you can extract more even from 0.935.
I was able to get 14641 on the FE (which I had until last week), following the [email protected] method. Didn't even touch memory for that one. So, I don't know... What's the average clock during the benchmark? And what about the other 3D Mark scores? Speedway, Port Royale, Timespy Extreme.On my Founders 5090 I'm struggling to crack 14,000 in Steel Nomad (13,960) with undervolt settings.
My power draw is a good 20% less over stock, but I wonder if there's a limit with what the FE can do as I'm a 1,000 shy of AIB boards it would seem.
. Definitely hope there’s room left when you pick a random high number to OC at and it doesn’t fall over immediately
