- 22 Jul 2012
- London
If only the specs were available online
How much space width wise does it take?
Is there's a smaller version like a 42inch one?
Brilliant thanksThe 49" is 115 cm wide.
The next smallest 1000R curved Samsung display is the 34" G55T
I can’t help you much with what you’re looking at as I have a single buttkicker pro under my seat.What do you good folks use for bass shakers?
I'd like to put shakers on each corner and one under the seat. I plan on getting 2 Simagic haptic motors for throttle and brake (my pedals are P2000)
I use the optical out on the PC mobo to a small amp for headphones. I'm thinking get a sound card with optical out- will any one do? I'd like to get Dayton BST-1 shakers (or the chinese clones) and I've seen the Slip Angle isolation mounts and mounts for the shakers to fit to them (they're actually HVAC isolaters which I found on Ali Baba for £6 each or so - I've asked the seller if the spring rate can be changed. The shaker mounts I've seen on Etsy)
What I'm not 100% on is what to use as an amp. Do I get one of the small ones? If I have 5 channels, what about the chinese receivers? I don't really want to spend loads on Behringer 3000Ds, I had a 6000D before which wasn't cheap.
100% you need a heel plate, I have those pedals and size 12 feet and there is no way I could have my feet rested on a plate that the pedals are mounted to they need to be raised up slightly.My new kit has arrived :
- 49" Samsung 1000R curved monitor
- SimLab XP1 pedals
- GT Omega Adjustable Pedal plate
The wider monitor and significant curve definitely improves the immersion. I will probably get a heal plate for the pedals to improve the comfort.
Pricing looks very competitive. All normal alpha bases have had a hefty price drop as well.You can now pre order the new simagic Alpha evo wheelbases that come in 9 12 and 18nm
Simagic Alpha EVO Wheelbases Pre-orders Now Available
Simagic's new line of Alpha EVO wheelbases is now available to pre-order from select International suppliers!www.overtake.gg
There's a separate adapter to front mount itPricing looks very competitive. All normal alpha bases have had a hefty price drop as well.
I'm ready to order one but I don't think you can front mount them even though it says you can. I can't see front mount holes in the pictures.
Where did you see that info?There's a separate adapter to front mount it
Yes. Good you found the info.Where did you see that info?
Bit weird that it needs an adapter, just stick holes on the front like the old ones. Seems like a money grab, except the bases are all now really cheap, that could have priced them higher and still sold loads.
Edit £50, so £800ish for the 18nm base and FM bracket
Great setup,I've been through most combinations of screens since the LFS days, (Triple 24, Rift 1, Rift S, 34" ultrawide) and have settled again back on triple 32" 1440p for my latest setup and I really think it's the sweet spot. Maybe poor eyesight and contact lenses was what really done it for me, but as good and immersive as VR was the FOV was the biggest killer. I've done 3 hour stints in the Rift S and it was fine, but with much less time to spend on sim racing now I find it far easier to jump in a 2d rig than VR.
Having 2 kids under 4 has pretty much taken me out of the loop for sim-racing over the last few years (and my irating plummeting from 5k to mid 3k), but I've been slowly getting myself back to a decent setup again after selling my Playseat Trophy and going for 8020:
Pro Simrig PSR3
Sparco Evo XL
Pro Simrig Triple stand but bolted directly to the chassis
Triple HP X32 (pretty good, 165hz, 1ms, not the best in the world but perfect for this)
Fanatec CSL DD
10 year old CSR Elite pedals, next on the upgrade list.
I do intend to build something similar to this for my son for maybe his 4th birthday or the following Christmas also: https://www.reddit.com/r/simracing/comments/ib76ph/custom_8020_kid_sim/
