Why do you need to get your fingers in?I bet redit would love my setup with it's spacing. But it's just enough room to get my fingers in, one I have completed the whole house I might respace it correctly.
Sometimes auto neg doesn't work as well as it should, you could try forcing manual 10 Gbps/full, or reinserting it.One of my SFPs is running at 1Gbps instead of 10Gbps, what do you guys think fiber cable or SFP itself?
To add more cable runs as I complete the house rewiring.Why do you need to get your fingers in?![]()
I'm still confusedTo add more cable runs as I complete the house rewiring.
What is the SFP model number and what switch is it in?One of my SFPs is running at 1Gbps instead of 10Gbps, what do you guys think fiber cable or SFP itself?
Stelly
Rear door, it's bolted to the wall. No side doors either.I'm still confused
Surely you just take the side off the rack, or open the rear door, rather than trying to get access through 1/3 of a U?
Missed that when I saw the picture earlierRear door, it's bolted to the wall.
That's not as easy as just poking my fingers through to feed it through the patch panel. Hehe why I have done it this way.Missed that when I saw the picture earlier
As long as you've left enough slack on the network cables, I'd just unbolt and pull the patch panels forward if you wanted to add more![]()
Ubiquiti UF-MM-10G 10-Gigabit Multimode Fibre SFP+ Transceiver, LC ConnectorWhat is the SFP model number and what switch is it in?
Does it work in a different SFP+ slot? Do you have any 1Gb SFP modules in the slots around the 10Gb one?Ill give that a go...
Its an aggregation switch (USW-Aggregation)
