- 30 Sep 2005
Well I'm afraid it's not great news. My headset arrived yesterday.
Software is a joke, took me an hour to get it powered on, worked for an hour then wouldn't work again. Took another hour to get going.
I've just reinstalled windows from scratch this morning and it does seem a bit better now, time will tell.
Lenses are very much like the pico 4, just with 10 degrees less fov. Glare!
Poor edge to edge clarity.
There is warping at the edges and in the middle. The middle looks floaty if you are reading menus.
OLED is OLED, great colours and blacks but you do need to change the display settings by boosting the brightness and contrast.
Brightness is ok, fov is usable.
Headstrap is a pain to get dialed in, which you must do as the sweetspot is quite narrow.
Comfort, it's fairly light but to get into the sweetspot it's almost sat on my nose. Think the quest3 with aubika strap was more comfortable.
No way can you ever use this as a monitor replacement, lenses are nowhere near good enough.
Sharpness, tried 4084x4084 and also 5000x5000 doesn't look pin sharp to me, it's not bad but probably a bit worse than say a crystal light
CA, not noticed any CA which is one good thing I guess
Is it worth £1,599.....no
Knowing what I know now would I buy it again....no
What should you do? buy the BSB2 or wait for something else
What am I going to do? I've asked for a refund, but if I don't get one I'll probably keep it till Christmas and sell for the pimax dream air (depending on user reviews, not youtubers!)
Takeaway....doesn't matter how good the panels are, the lenses are critical to making a good vr headset
