Oh, I missed that. Thanks for the video.Did you see mine I posted for you earlier?
Nice. Thx man. What PSU you got?Sure here you are:
And heres my OC run. Need to dial that in more, but I'm very happy with the card so far
Np, it's a be quiet! Straight Power 12 1500 W 80+ Platinum.Nice. Thx man. What PSU you got?
IINNEX:
Do you use an original 12VHPWR cable, which came with psu ? It’s ATX 3.0, so isn’t it a risk if it’s not 12V—2x6?
In my country, there is available only Straight Power 12 1200W. Is it the same as 1500W version? Expect powerI am using the original 12VHPWR native cable, the PSU comes with 2 of them. It works perfectly fine.
I can return my SUPRIM and shop can return money back. HoweverI think your over thinking things slightly. So far it's all been random (look at the awful Suprims and the amazing ones etc). Just buy from a retail with a good return policy and roll the dice IMO. Rule out what you can control i.e buy a card with known quiet fans, a PSU from a reputable brand etc.
Only you can decide. The card isn't broken, it just has a bit of coil whine. If you can't live with that, then return it. If you can live with it, then keep it.I can return my SUPRIM and shop can return money back. However
I’m not sure if it’s worth returning my SUPRIM. You probably heard my coil whine, right?
I really understand you.Only you can decide. The card isn't broken, it just has a bit of coil whine. If you can't live with that, then return it. If you can live with it, then keep it.
Yes its the same ATX 3.1 version, just a bit less power. Here in the UK the 1500W was actually cheaper for some reason, hence why I got this one.In my country, there is available only Straight Power 12 1200W. Is it the same as 1500W version? Expect power
I don’t know if you’ve seen my video. Would you personally keep the SUPRIM I have or not?
It's hard to tell from a video. There are all kinds of issues around audio-balance that mean they aren't necessarily a reflection of how the thing sounds when you're next to it.I really understand you.
Basically confirming - the more fps you're pumping the more whine you should expectSo, I made a better videos of my SUPRIM.
TimeSpy 270-420fps
Superposition bench 320-400fps
Speedway bench 150fps
Yes, that’s right. But is my cw acceptable?Basically confirming - the more fps you're pumping the more whine you should expect
