Mines running 24/7 at 3200 ish MHz which is like +200 MHz for me. I can get up to 3300 ish if I juice it up but can’t be bothered and it’s not 100% stable. +2000 MHz on the memory too. Decent gains in performance seen as well!What over clock is everyone getting? I've got +400mhz +2000 Memory and getting +16 fps 4k Uncharted, +10fps Returnal 4k. I need to do more tests to see if it's stable. But that would put it overclocking better than any 4090 I had.
I’m very happy with mine though if I had a diff model I’d probs lean more towards 2900 ish with fewer volts but mine runs sub 60c. And as the radiator is blowing out the front of my case, my body temperature gets to about the same level
