Don’t know if this is normal but when switching the monitor on using the button, it’s taking two presses to come on most of the time.
Thankfully I’m not the only one.Think mine does that
its a difficult decision. Maybe the Alienware due to cost. I cant see any issue with having a 27' next to it thoughSo i still cant make up my mind , this or the Alienware AW3225 QF ? Suggestions ?
I have a large enough desk and want a twin screen set up , im not opposed to the curve of the Alienware ( can get it with a Blue Light discount ) but could i place a 27 oled screen alongside it , this would be a cheaper model for discord , tube and browsing ?
Help
This isn't exclusive to Asus (Gigabyte offer it too) - but it's also something that you can just do yourself on any monitor.whether you want to use the aspect ratio control, so you can simulate a 27" display and get a bit more FPS out of it for competitive games (Asus only)
I've had both and the VRR flickering was awful on the Alienware, I got this for £875 and very pleased with it, VRR flicker isn't bad at all on this. The AW I couldn't live with, was horrendous. The ASUS feels much better built as well imo.So i still cant make up my mind , this or the Alienware AW3225 QF ? Suggestions ?
Help
Today I learned! Thanks for the infoThis isn't exclusive to Asus (Gigabyte offer it too) - but it's also something that you can just do yourself on any monitor.
On a 4k 32" to simulate a 27" display you just create a custom resolution of 3288 x 1850, then you can use something like DisplayFusion to bind it to a hot key (Alt + Shift + F12, for example) and it will swap from full 4k 32" to the 27" cropped view.
I did this on my LG 32" 4k for a while whenever I was playing FPS games.
I use the same settings and even in bright light it looks goodSo far this is a great monitor ,I’ve updated the firmware and the hdr10 in console mode with dynamic brightness boost works really well .I'm coming from a Dell and I learned that I don’t really like curved monitors .
It is a really great monitor , so far I am really impressed with it .I use the same settings and even in bright light
Yeah, seen on YouTube they will be doing a glossy woledWas tempted to finally order one only for ASUS to announce a new range coming in August!
I think the proximity sensor is a great feature,it’s nice that it does a pixel refresh/ clean automatically when your not in front off it .I use the same settings and even in bright light it looks good
The main difference is that the ASUS ROG Swift OLED PG32UCDM includes Dolby Vision HDR support through firmware, whereas the PG32UCDMZ is equipped with a dedicated Dolby Vision feature,
making it potentially more suitable for users who watch a lot of Dolby Vision content.
Both monitors are 32-inch 4K QD-OLED displays with high refresh rates, low response times, and excellent color, but the choice depends on your need for Dolby Vision and whether the M-series (UCDMZ) or the standard version (UCDM) of Dolby Vision is preferable for your setup
