- 6 Sep 2016
pity there is no easy method of using optiscaler, you have to copy it into every game? Shame it's front end util which'll scan your HD for games and do what it needs to do.
They had a mix of Samsung and Hynix GDDR6 on their last gen, it's nothing new for them to use different manufacturers VRAM on their boards. It was hit and miss which worked better with both providing good to poor overclocking capability. Just basically boiled down to luck.But annoying, feels like this should've been done for release. So now when AMD release a product you have to weigh up if they might release a new version shortly after release with revised components, no doubt letting resale value off the original.
thats still a £60 increase on launch, my reaper was same as pulse at £569. the $50 rebate is around say £40 so someone obviously making some extra margin out there
Just tried and it works, thanks!I'm using Optiscaler to get FSR4 working on the game pass version. Annoying this happens all the time with game pass games.
My Hellhound 9070xt has Samsung Memory - I got it on release.Yeah it apprantly depends on the batch as the newer batches will almost certainly have the samsung GDDR6 *on the higher end models* so the only way to truly make sure you get the better VRAM is to wait until the stock of 9070XT's has been refreshed once or twice to get the Hynix stuff out of circulation
Have you tried memory overclocking? Any different to Micron?My Hellhound 9070xt has Samsung Memory - I got it on release.
£570 to £630 isnt £60 but £50?, hell best i have a word with my old teachers, well i would have to reincarnate them like, but i guess these things need to be doneSorry to be pedantic but it’s actually only £50 more than launch but the added benefit of enjoying the card now as @Finners mentioned prices might come down but may be some months away.
The pulse was £619.99 elsewhere so that’s £50 over msrp.£570 to £630 isnt £60 but £50?, hell best i have a word with my old teachers, well i would have to reincarnate them like, but i guess these things need to be done![]()
ah as thought he said £630 hence confused me lolThe pulse was £619.99 elsewhere so that’s £50 over msrp.
Mine has Hynix also a release day cardMy Hellhound 9070xt has Samsung Memory - I got it on release.
Don't know my hellhound sits about the same in my not so op cooled nzxt h510 case ,just the card I thinkI'll be honest, I caved and picked up a Sapphire 9070XT Pulse a few days ago. I noticed that it also has Samsung memory, it might be my OP case cooling but the memory temperature hovers around low to mid 70's while gaming.
