- 14 Nov 2002
- Under the Hill
green oak sleepers, coach bolts, impact driver, spade, loose gravel, spirit level.
You'd be surprised with a pilot hole, but the torque isn't nice to manage with a decent drill. An impact is just safer.Thank you, guess my budget Bosch drill (present) ain't up to the job then.
We've decided to do edging bordering instead. Both beds back onto a fence, edging would be easier and cheaper and take less space.Sleepers are expensive, so do your sums to work out total costs first.
An impact driver is worth every penny when putting in lots of screws. I've been using these in 75mm and 100m lengths for some new raised beds:
For the inside liner, I've been using DPM from Screwfix. Cut it to size and then stapled into the timber.
Thought I'd post my garden, mainly to revisit this post in 5 years and hopefully see a big difference.
Started late last summer so all fairly new changes.
Typical new build square of turf, unfortunately north facing garden.
with typical new build mini budget patio
First thing was to sort the patio out
Went for a simple grey porcelain, much much nicer than old, and a userful 11 x 3m
Better patio but still such a new build boring square. Decided to start with a shed.
4x3m shed. Unfortunately I gave the base a tiny slant to help rain run off, which meant it wasn't a perfectly flat base, which meant the shed is a little wonky in places and the felt has a constant ripple..
Next we dug a stone path, but the area was completed waterlogged, so made a stone soakaway and connected it to the main drain
We built some very chunky, two-tiered planters. The aim is to grow things a couple of ft higher than the fence, which would in turn block out lots of the houses on the left.
SO much soil to fill them. Have since planted some cherry blossoms and flamingo willows on the back level, with some small acers between them. Hopefully in 3-5 years, that side will have grown nicely
We wanted next go get some height on the back fence, and also enclose it a little more. Wife really wanted a laurel hedge. Again, 3-5 years should reach above fence height and provide some needed greenery in the gardens
Wet winter has ruined the grass but at least we've started to turn it into a garden!
Thanks for coming to my ted talk
We are very novice when it comes to gardening, so would welcome any tips or advice, especially around planting things to help 'enclose' us a little more.
That's a great idea. Thank you.I'd have thought clingfilm would hinder airflow. Most people use the white fabric style sheeting which allows moisture and air flow.
