Lovely looking car Draeger. The red & grey looks really good (I have a G22 in the same colour but with black M Performance seats with blue stitching)
I have just put CSC7's on the car & I am very impressed with them. I see you have now gone with PS4S on the car. I would be very interested in your thoughts on the matter if you have a moment please
Thanks, I still glance backwards over my shoulder every time I park it
Doing some routine checks today and checked my tyre tread depths.
Previous tyres were Continental CSC7's and I couldn't fault them but when it was time to replace them I wanted to try the internet 'go to' tyre, the Michelin PS4S, so I could see if I felt any difference between them and the Continentals. I should also point out that I went for BMW OEM * marked versions of the PS4S which were ironically cheaper than non * marked for some bizarre reason.
So far I'm just as pleased with the Michelins but what I was curious about was mileage/tread wear.
My CSC7's were down to 3mm ish on the rears after about 6500 miles. The Michelins are now down to 5.5mm ish after just shy of 7000 miles so I'd guess they are potentially on track to run to maybe 9000-10000 miles before they hit 3mm. Quite a difference in longevity.
Deciding which tyres perform best would be almost impossible as they are both at the top of their game as a UHP tyre. But that wear rate might well mean that for me at least, the Michelins will be opted for again, next time.
