Caporegime
- 9 Nov 2009
- Planet Earth
Possible RTX5070 Super 18GB and RTX5080 Super 24GB:
he goes of on a rant about why 9070xt is better than 5070ti, 5080 and 4090 but with some caveats like bad Nvidia drivers, crashes, missing ROP, catching fire etc etc, also super variants 7-15% faster with more ram and possibly faster clocked hence where the performance comes from.TLDR?
What AMDPower said and FSR4 is coming to RDNA3.TLDR?
Thats got to be another NVidea driver **** up or some weird coding bug in Veilguardlol buying the 8gb 5060ti ain't a good idea without a pcie5 motherboard
https://ibb.co/0phZ6hPm
Die Nvidia GeForce RTX 5060 Ti mit 8 GB im Test: Einzelne Benchmarks der RTX 5060 Ti mit 8 GB vs. 16 GB
GeForce RTX 5060 Ti 8 GB im Test: Einzelne Benchmarks der RTX 5060 Ti mit 8 GB vs. 16 GB / Assassin's Creed Shadows / Black Myth: Wukongwww.computerbase.de
With the 5500 XT and 6500 XT, the reason was usually because it ran out of VRAM and that increases the use of the bus, so I'd guess that's what we're seeing with the 5060 Ti, but I don't know if the worst hit games are the ones with the highest VRAM usage.Thats got to be another NVidea driver **** up or some weird coding bug in Veilguard
Thanks mate. The block looks goodPlayed with Alphacool waterblock today. I like the looks and build quality, the 5090 runs much cooler now, but the coil whine is a lot louder though.
The Zotac backplate was apparently plastic and it was used as passive heatsink because Zotac used thermal pads between the backplate and the VRAM. No wonder the VRAM was Idling at 70C.
At least now I am back to 100% watercooled.
https://ibb.co/67tXn0zP
https://ibb.co/1t4q2ZQ3
https://ibb.co/HDBrXy2Q
How many drivers have you tried? Which games? What kind of crash is it? (e.g. freeze, CTD, BSOD)Does anyone have a idea on what I should do? Any fixes your aware of, is this the norm?
I recently bought the same card and i had issues with the latest drivers and playing certain games. Swapping to the January drivers fixed these issues for myself.Hi I received my msi trio 5090 about a week ago now and ever since all ive had is a nightmare. It crashes about 15mins into literally every game and ive tryed a lot of things online to fix it. Does anyone have a idea on what I should do? Any fixes your aware of, is this the norm? or once again have I been delt a duff? Thanks guys
There's already support for it on Linux. I don't have an RDNA3 card to test with, but reports are that performance is pretty bad compared to RDNA4 due to missing native FP8.What AMDPower said and FSR4 is coming to RDNA3.
FSR4 Support - AGS · Issue #2398 · HansKristian-Work/vkd3d-proton
Please describe your issue as accurately as possible. Include screenshots or videos if relevant Using Optiscaler you can get fsr4 on many titles on windows, on linux it works for 3.1 but when i try...github.com
It's currently enabled using a custom patched driver, with vkd3d (dx12 to vulkan translation layer) and optiscaler.Is that official support or hacked to work on RDNA3? The PS5 PRO is getting a version of FSR4 but supports INT8 and not FP8 AFAIK. RDNA3 supports INT8.
Performance on RDNA4 is fine, so likely just the result of missing hardware support in RDNA3, which who knows, may be possible to optimise for.
It may require a lot more than that which is likely why AMD are not jumping to confirm anything.
