- 29 Aug 2010
- Cornwall
Corsair AX1200 and a Superflower Leadex Platinum 1200W.what 2 psus have you tried model etc? could it be that the psu are fine with the 4060ti as it has a lower wattage requirement and the 7900xt its just too much for them? could also try looking at the psu rails in hwifo specifically in the mobo section 3v/3.3v/5v and 12v, don't run cod, but check at idle are they close to the ratings (i.e is the 12v rail within 10% of 12v etc)? try the running another lower demanding game, check them again are they still close to the ratings? after having a psu that could not provide the correct voltages close to the rails, its one of the things i usually check now when it comes to gpu crashing although in my experience that issues causes a full system reset and not a crash but you never know and wouldn't loose anything but time.
edit: worth checking swapping the gpu as it will potentially eliminate things like cpu etc, when you swapped from the 4060 to 7900 did you a run DDU and fully nuke the nvidia drivers? most peopl,e say you dont need to bother now, but it is worth doing as it gives you more of a clean start than just an uninstall.
Didn't swap from the 4060Ti exactly, this was a rebuild that re-used some parts but it was a fresh windows install.
