Number one is what I went with, easier to adjust them, easier to mount one at a time, and stronger overall mounting. I made a jig for drilling the mounting holes to space the brackets correctly.
I had thought about cross bracing with perhaps solar PV rail (this would push the panels further away from the wall) or a length of aluminium angle, and also make it more difficult to adjust them due to the weight.
Cross bracing would likely be more expensive than an extra set of adjustable brackets, and if you used one adjustable mount between two panels you'd need something to mount both to the bracket, sort of back to a cross brace.
That's what I was thinking of doing, getting some batton laid down on the floor and mocking up the panels/brackets on to the batton. Marking the holes, drilling them out and then use that to transfer the layout to the wall. Much easier when you're up a ladder to hold a template out and drill. No messing.
OK, I'll go with option 1 as well then. Seems the most sensible approach with regards to the support and adjustment side of things.
Quick question as I have you... cable sizing. I have 6 panels on an 18 metre run, I'm thinking the 2 core PV Ultra 4mm cable is going to be sufficient using say these DMEGC 450w panels as a guide and running it through various calculators. Most of them recommend 16AWG which feels a bit anaemic to me.
