*** Official Ubiquiti Discussion Thread ***
Can't say the UDR7 fan bothers me but then again it is in the Hallway. Currently sat at 65c (I'm on the normal firmware and have not opted into the EA).
i didn't mind the buzz you get used to it, but quiet go so hot i didn't dare leave it running, it was in the 90s at times with an ambient of early 20s
Ubiquiti just sent me this about the temps:
After checking with the development team, there's no reason to be concerned at this time. When set to Quiet mode, the device continues to manage its thermal profile appropriately. While a rise in temperature is expected, it's still within safe operating limits. If needed, the system will automatically adjust to maintain stability and protect the hardware.
Finally got my backside in gear and configured Usenet downloads over Nord Wireguard VPN. I'm not sure why NordVPN make it so difficult to get Wireguard credentials, but I got there in the end with a bit of PowerShell. Now I can download Linux ISOs over a VPN at ~90 MB/s using the UCGF.
Are there any rumours of Cloud Key improvements? The CK+ is really old and has a pretty low device limit, the CK Enterprise is ridiculous overkill. It seems wild to spend £50 less than the cost of a Cloud Gateway Fiber for something that cannot manage as many Unifi devices and also isn't a gateway, but I have visions of using a Cloud Gateway as the host of the Network application but not actually wanting it to be the gateway being very messy and causing problems.
Not interested in hosting things elsewhere, for a start I have no need for it and also £30/month very quickly costs more than buying hardware.
