- 10 May 2004
- Middlesex
Thats great. I've ordered, thanks!I got this. It's glass, it comes with a guide for alignment and you get 2 go at it. It is half the price of the Spidgen.
I see they're up on the official Nintendo store at the moment just in case someone still hasn't managed to pre-order.
That makes me feel better about having the Pro 2 on pre-order. I just can't deal with the Joy-Cons so it was a bit of a no-brainer for me.Seems some more info is coming out about the Pro Controller 2 and it sounds like its excellent. The previous gen was excellent and this one sounds like a good upgrade on that. Some are saying its the best controller they have ever used. At £70 it had better be bloody good. I would have to try one before dropping that sort of money. The main thing that will annoy me is the old one not turning on the console.
I bought one as I will rarely if ever play it undocked, so figured it was worth the investment. At least until I sell the whole thing once I’ve caught up on the Zelda, Mario and Metroid games I’ve missed due to not having picked up a Switch 1 before.Seems some more info is coming out about the Pro Controller 2 and it sounds like its excellent. The previous gen was excellent and this one sounds like a good upgrade on that. Some are saying its the best controller they have ever used. At £70 it had better be bloody good. I would have to try one before dropping that sort of money. The main thing that will annoy me is the old one not turning on the console.
Best deal yet, well done. The rest of the world, especially US get shafted. And we get the usual slap in the face here in Blighty. I'm still annoyed that Japan is the only place that gets a cheaper region-locked model, not like it even gets manufactured over there, still gets made in places like China, Vietnam, Taiwan, etc. Gone are the days of importing cool region-exclusive limited edition consoles.Preordered the Mario Kart bundle this morning. £385 here in NZ for the bundle. Probably not the end of the world and stock market has been strong recently. Why not.
Would be fine if they were always solid, Unfortunately that's not always the case.A quick question on the VRR when docked issue. Are or will most games on the switch 2 be capped at 60fps so if you are playing at 4K/60 this is not really an issue as long as frames are solid?
It uses microSD Express cards and not regular microSD cards. You could pick one up as a pre-order or just use the internal storage until that runs and get a card then. Everything else is pretty much optional. The Joy-Cons connect to the Switch and get charged that way. The Pro 2 controller does sound good. I have one on pre-order myself but you don't need it as the Joy-Cons will work fine.I've preordered a switch 2 bundle deal for my boy's 6th birthday in June. I'm a bit out of the loop and not sure what items are absolutely necessary and what aren't. Is a micro SD card needed? Is a controller charging dock needed? Anything else that is a must have purchase?
Let’s be realistic, the switch 2 isn’t rendering at native 4K in any game. It will be upscaled 900p via DLSS at best for the most part.A quick question on the VRR when docked issue. Are or will most games on the switch 2 be capped at 60fps so if you are playing at 4K/60 this is not really an issue as long as frames are solid?
I am doing that but I don't think it is essential.Anyone any thoughts on is it worth it to go from Pro Controller to the V2? Unsure if its worth it
It's worth upgrading the controllers if you want to wake the Switch 2 when docked.So from that list the only thing that would be helpful is extra buttons, shall hold off for now then unless games start making it essential to have them. Thanks all!
You cannot exit sleep mode on Nintendo Switch 2 using the HOME Button on Nintendo Switch controllers such as Joy-Con and Nintendo Switch Pro Controller
