**THE NVIDIA DRIVERS THREAD**
New GRD -
Release Highlights​
Game Ready for GeForce RTX 5060
This new Game Ready Driver provides the best gaming experience for the latest new games supporting DLSS 4 technology including F1 25 and Dune: Awakening, as well as the Full Ray Tracing update for NARAKA: BLADEPOINT.
Gaming Technology
  • Adds support for GeForce RTX 5060 desktop and laptop GPUs
Fixed Gaming Bugs
  • [F1 23/F1 24] Game crashes at the end of a race [5240429]
  • [Diablo II Resurrected] Game displays black screen corruption when using DLSS [5264112]
  • [SCUM] Game may crash after updating to R575 drivers [5257319]
  • Shader disk cache will not be created with certain games if OS username contains unicode characters [5274587]
Fixed General Bugs
  • Flickering/corruption around light sources in Ghost of Tsushima Directors Cut [5138067]
  • Cyberpunk 2077 will crash when using Photo Mode to take a screenshot with path tracing enabled [5076545]
  • EA Sports FC 25 may crash during gameplay [5251937]
  • [Forza Horizon 5] Game may crash after extended gameplay [5131160]
Another day, another driver, another black screen after installing that driver.
I know it's a forlorn hope, but maybe now the full launch range of Blackwell GPUs is released they can actually focus on fixing some ****?
you wish, jensen too busy earning 1m every time he says ai or does some robot ****
any idea what unicode characters are causing this.. nothing thats readily available on a normal keyboard i presume
"Shader disk cache will not be created with certain games if OS username contains unicode characters [5274587]"
updated this morning. Got a black screen and was unable to access boot options. Had to use system restore from a usb drive to get the system back
That sucks !
I have honestly had zero issues with my 5080 since I got it 2'ish months ago aside from 1 time my screen randomly went black and then came back on again a minute later.
In the release highlight notes above it says
Fixed General Bugs
I've just tested........and it's not fixed. Why do Nvidia keep releasing 'fixes', state that they work, and they do not work.
Fixed General Bugs
I don't know where the poster above got that from, nVidia can't be consistent with their websites, it's in the open issues for the driver on the official forum
Open Issues:
[RTX 50 series] Dragons Dogma 2 displays shadow flicker [5252205]
[RTX 50 series] Video playback in a web browser may show brief red/green flash corruption [5241341]
Wuthering Waves may randomly crash during gameplay after updating to R575 drivers [5259963]
[RTX 50 series] Enshrouded crashes after launching game [5279848]
[NVIDIA App] Adding an unsupported app to NVIDIA App and enabling Smooth Motion forces it globally to other apps [5243686]
[RTX 50 series][Battlefeld 2042] Random square artifacts may appear around lights during gameplay [5284105]
Changing a setting in the "NVIDIA Control Panel" -> "Manage 3D Settings" may trigger shader disk cache rebuild [5282396]
[Gray Zone Warfare] Game may crash on startup [5284518]
[NVIDIA App] Setting "DLSS Override - Model Presets" to "Latest" and "DLSS Override - Frame Generation" to "Use the 3D application setting" forces 2x Frame Generation mode regardless of in-game setting [5214136]
******** damn
  • Haha
Reactions: mrk
Tried this, it made the game extremely laggy.
The game seems to run like arse at 4K for some reason - with a 4080 Super at 1440p I can set everything to ultra with a base 60-70 FPS and ~120+ with frame gen and it works pretty well, if I go to 4K even with settings reduced to get the same frame rate it is quite choppy.
With frame gen on in the game you really need V-Sync off unfortunately, which sometimes results in tearing as otherwise it does get kind of laggy even with a v-sync on at 100+ FPS.
I recommend forcing the latest DLSS version on the game and setting r.NGX.DLSS.AutoExposure=1 in the engine.ini (there are guides for doing this) as the image quality is vastly improved this way.
Open Issues:
******** damn
I wonder if that's that's the reason that when I select anything higher than 2x in games with MFG, Like 3x or 4x, It does nothing ? Guess it's DDU time and only installing the driver.
EDIT
Yep, Sure enough Nvidia App was the issue.
What's a good alt to Nvidia app though for game recording, OBS? I want to retain 4K 60fps recording minimum obviously with zero fps impact whilst doing so.
Been using OBS for years, it just works and has tons of codecs these days, also has latest AV1 for a while now.
  • Like
Reactions: mrk
