The tyre will be fine if it only goes flat on the bottom, the time to worry is if it goes flat on the top, that's when things really start to get scary!!I'm scared to remove it incase the tyre goes flat.
That's what she saidPull it out.
Might not be so easy if it's a run flat tyreThat looks like it’s easily repairable.. I’ve had 2 screws in my tyres in the 4 years, and just screwed them further in and driven to the garage to get them repaired..
Still should be repairable - think the sides are more reinforced.Might not be so easy if it's a run flat tyre
