Is this safe?
26 Aug 2023
Uk
I can hear it going round. Its in the back rear passenger tyre.
Can it be plugged? I'm scared to remove it incase the tyre goes flat. And everything is shut tomorrow because of bank Holiday so it will be Tuesday i can get it sorted.
have you got a spare to put on ?
how far do you need to travel ? (if at all)
should be ok if your not going up and down the motorway etc, if to the shops and back that's fine, otherwise i wouldn't risk it
I'm just trying to make out the writing on it.
...sword...
of..
Damocles...
Or something.
I'm sure it's fine
Seen that before because I forgot to pay my Dartford Toll Charge. I checked my ring door cam and I saw Dartford Toll Charge employees placing items infront of my tyres on the drive way.
After showing them the footage, they paid for a replacement tyre and waived the charge.
Well ard', innit'.
That looks like it’s easily repairable.. I’ve had 2 screws in my tyres in the 4 years, and just screwed them further in and driven to the garage to get them repaired..
Should be easy to plug - even DIY shouldn't be hard. If left in a good chance it will come out at random while driving though and the tyre deflate over half a mile or so.
That's an old golf shoe stud, a metal one at that since the modern ones are plastic / rubber. The screw part that goes into the sole of the shoe will be shallower than the groove in your tyre. Just flick it out.
You sure? I thought it looks more like one of these:
@katy81 when you pull it out please post loads of pics, I won't be able to sleep until this is resolved. Thanks.
