- 2 Aug 2016
- Third Earth
Another day, another 5090.
Why have you got another one? Have you secretly won the lottery?Another day, another 5090.
Why have you got another one? Have you secretly won the lottery?![]()
what case is that , jonsbo? or corsair.Another day, another 5090.
where are those cables from ive never seen ones like that before only normal braided and ones with oled displays on the plug.Why not?
You can get it braided AND RGB!
ive been seeing these popping up on YouTube a lot been tempted to buy one myself, loads of good reviews for them.Great bits of kit aren't they - v. easy to setup and they work really well. Solved my issuue with using Mac Mini Headless Servers with encryption anyway.
thanks, ive never seen the hub before but I have seen that yellow nvme drive. I seen it when looking for a enclosure for my steam deck ssd when I upgraded it. I ended up going for the ugreen one instead.Search for "Fast Charging RGB Cable 100W Breathing Light 66W Type C USB C Data Cable for iPhone Samsung Huawei 30W Quick Charge for Xiaomi" (Talk about putting in every word to cover the SEO!)
I also got this from the same place today. Moved the nvme in the Sharge (yellow) enclosure with a fan into something fanless and a hub. It even have Magsafe for the phone. Comes with a metal 3M thing to stick on the back of the Macbook screen but I will just use it as a hub on the table when travelling.
Adds SD/MicroSD, USB-A 3.2 10Gbps, USB-C 10Gbps, 100w PD passthrough, 4k/60 HDMI out and 3.5mm audio.
Old noisy hub...£30. This one, £22.
If I had to guess, a bit of colonisation. Also if the next image @arknor posts is a magnifying glass then that feels like a red flag.What are you doing with them?
