Another day, another 5090.
where are those cables from ive never seen ones like that before only normal braided and ones with oled displays on the plug.
Search for "Fast Charging RGB Cable 100W Breathing Light 66W Type C USB C Data Cable for iPhone Samsung Huawei 30W Quick Charge for Xiaomi" (Talk about putting in every word to cover the SEO!)
I also got this from the same place today. Moved the nvme in the Sharge (yellow) enclosure with a fan into something fanless and a hub. It even have Magsafe for the phone. Comes with a metal 3M thing to stick on the back of the Macbook screen but I will just use it as a hub on the table when travelling.
Adds SD/MicroSD, USB-A 3.2 10Gbps, USB-C 10Gbps, 100w PD passthrough, 4k/60 HDMI out and 3.5mm audio.
Old noisy hub...£30. This one, £22.
I read quite a bit about how Google had finally made the changes necessary for Android tags to be worthwhile. I also read about the Moto Tags being the only ones that used wide band, or whatever it's called...
thanks, ive never seen the hub before but I have seen that yellow nvme drive. I seen it when looking for a enclosure for my steam deck ssd when I upgraded it. I ended up going for the ugreen one instead.
Messor Barbarus Queen that lost a leg in the post it seems.
should be all good according to googlefu
The black specs specs are poop, the white out of focus shapes are eggs.
crap pics but your not supposed to disturb them in this stage, they seal themselves off in a dark chamber in nature.
Her first home should be arriving in the next few days, but she will live in a tube for probably 1-2months
eats mostly seeds with they process and store in the nest
We have a place near us called The Bug Parc and the ant setup there is pretty incredible. Don't think I'd want them in my house though!
Something actually useful for once, a right angled Type-C adapter so the keyboard cable doesn't get in the way of things and makes it look neater :cool:
