From what I am reading on the PFD Discord, owners are very happy with them so far. It's not perfect, but the flaws are very liveable.Depends how good they are.
The resolution can likely be increased a little but yeah the chipset is definitely a limiting factor.I've read that at the moment VD renders games/apps at the same res as the Q3on the PFD MR due to the chipset on the PFD MR not being powerful enough to encode a 4K display, IDK how true that is. Hope it's not true.
I guess in time then something similar to QGO or QGO itself could overclock the chipset like it does for Q3/Q2/Pro to give it more oomph.The resolution can likely be increased a little but yeah the chipset is definitely a limiting factor.
This is not a headset if you want true 4k gaming visuals you will need to buy a DP headset for that because no wireless device can do it.
ALVR is a competing streaming app and you can increase the resolution beyond VD.
Yeah, its just a HEAVY price to pay, the PFD is basically 3-4x the price of a Quest 3. You are basically getting worse lenses but with far better panels due to OLED. However, the effective resolution while PCVR gaming will be around 3k-ish due to the encoding limitations of the Snapdragon chipset it uses. I guess 2027 is when we will see VR headsets with chipsets powerful enough to stream 4k wireless.Still the lack of SDE and the OLED colours would make this far more appealing than the Q3 even at the same render resolution. I play Skyrim VR on the Pro instead of Q3 simply because the colours and contrast are so much better, even though it's slightly lower resolution.
Mine was shipped from China yesterday, ordered 9th June, shipped by 13th June, afaik it should be here within a week or 2. I'm really looking forward to it, Richdog has made me lower my expectations somewhat which is probably a good thing, the lenses aren't as good as the Pro's or Q3's (tbf no-ones lenses are as good as these I think).
Yes the funny thing with that review is that the guy was apparently not even using the new monster resolution mode that is coming to virtual desktop in July. So what he was calling a very clear and high resolution image was actually running at quest 3 settings on the play for dream which means in reality it's a low resolution and not very clear. So basically he does not have a good eye for detail there.doesn't look like option for grips
Alyx footage i didnt think was great, but might have been panels
Mic is bad
