- 27 Jul 2005
- The Orion Spur
Yeah, might need messing with the HDCP. Try wiring direct to TV.
Possibly, is it ultra High Speed compatible? I'm about to try mine through the AV receiver.
Just finished transferring my account across, I'm quite surprised how good the screen is, it's not OLED quality in terms of inky blacks but the higher sharpness and resolution are immediately noticeable, viewing angles aren't too bad either, darker games like Hollow Knight and Ori will definitely take a hit but better than expected, extra size is nice too, it makes using the unit on it's stand as a 'mini tv' a lot more useable, the magnetic controllers are a nice touch, kind of feels how Nintendo would've liked it to of been originally, other than that system feels nice snappy and responsive.
Just downloading MK now, looking forward to giving that a bash.
Is the hub HDMI 2.1?I plugged my Switch 2 in my HDMI hub, but I am guessing the hub could not handle the signal output from the Switch 2. As soon as I plugged it straight into my TV, the dock worked perfectly
I saw somewhere Nintendo may have wanted to go with magnetic joy cons originally but couldn't make it work properly so they changed it to the rails.
Surprising how well they work, I don't feel worried about one suddenly coming lose, and even pulling on them, it takes quite a bit of force to rip it off, they feel much better than the old rail system with less wobbling.
For those who’ve had a good go on it now, does it feel like an upgrade in every area over the previous OLED model?
I’m still umming and ahhing over picking one up.
Not the screen but everything else is a big enough upgrade to compensate for the screen downgrade imo.
YehOk solved the HDR issue at 4k. It was setting on my TV.
Am I right in saying there is no VRR on docked mode (on TV)?
I really hope they come down in price because that amount is ridiculous. I'd be willing to buy if one drops to £50. At least you can still use them in a normal Micro SD reader, it'll just be slower. The Nintendo branded 256GB one topped out at 100MB/s read and write when I benchmarked it.Blimey. £85 for a USB microSD Express reader. I was thinking of getting one for my Mac but at that price...
Ah so it's the hub then. Well that's a massive pita for me lol.I plugged my Switch 2 in my HDMI hub, but I am guessing the hub could not handle the signal output from the Switch 2. As soon as I plugged it straight into my TV, the dock worked perfectly
How come your using a hub? not enough connections on your TV I'm assuming?
Get a AV receiverI've got about 12 different devices set up at the moment and only 4 HDMI ports on the TV lol.
That HDMI switch might be good yeah. I definitely need something more updated than the one I'm using right now, which is donkeys years old. I'll take a proper look at it, cheers!
Its actually cheaper on Amazon.How come your using a hub? not enough connections on your TV I'm assuming?
would this help?
HDMI 2.1 Switch Splitter 120Hz 5-port HDMI 4K 120Hz Splitter Switcher CEC 48gbps HDMI 2.1 Switch 8K with remote HDMI HDR 8K 4K - AliExpress 44
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
