- 19 Oct 2002
- Shakespeare’s County
I’m just working out how much better this integging go drive. I was lucky so go the £20 a month version for all charging and the day rate is down at 23p.
That’s per wheel though rather than spilt across an axle on the ID.7…
Have decided against getting a dedicated wall charger for it just yet; the car will be parked on the driveway just in front of the garage, and there's a normal socket just inside the garage door. I'm led to believe that that should be enough for charging the relatively small PHEV battery (17.8Kwh I think) up overnight, so for now we will rely on the granny charger. Would welcome other PHEV owner experiences on this though.
i am risking sounding like a dumbass (nothing new there then"The two in-wheel motors at the rear develop an instantly available total torque of 4,800 Nm for responsive performance."
Sounds like a combined figure to me.
) but if they are in wheel motors wont 4800Nm of torque be significantly more performant than the same potential 4800Nm if through an axel?yep combined .. it's an f=ma application (on a roll ? no it's a coffee break - sorry)"The two in-wheel motors at the rear develop an instantly available total torque of 4,800 Nm for responsive performance."
Nice car the CX60 we we're torn between that and the XC60 and went for the latter just because it had a turbo motor for towing when battery is depleted but the Mazda was much better value.Have decided against getting a dedicated wall charger for it just yet; the car will be parked on the driveway just in front of the garage, and there's a normal socket just inside the garage door. I'm led to believe that that should be enough for charging the relatively small PHEV battery (17.8Kwh I think) up overnight, so for now we will rely on the granny charger. Would welcome other PHEV owner experiences on this though.
I'm sure it won't be like this for ever but I will enjoy it for now.That is potentially suitable but there would be very limited headroom for any other power draw in the garage.Speaking of charging a ev, mine arrives next Tuesday and for a while I plan to just charge it by 3 pin until a charger is installed, there's a public charger nearby if I need to quickly top it up if we've a long journey. We've Octopus on a 1 year fixed tariff so my plan is to go over to their intelligent go version so I get 7 hours at 7p.
In the future a charging unit would be placed on the detached garage outer wall as it already has power going to it.
In looking at the wiring going to the garage it looks like it is suitable for the load a charger would have, but the consumer unit would need replacing which I could do if required.
Photo below, any thoughts much appreciated:
Thanks for your prompt reply, that seems fine as there's nothing going to be powered up at the same time the car is charging.That is potentially suitable but there would be very limited headroom for any other power draw in the garage.
You’ll only have 8A to play with when the car is charging which is probably fine in practice.
That’s on the assumption the black cable feeding it is in fact 6mm or above.Thanks for your prompt reply, that seems fine as there's nothing going to be powered up at the same time the car was charging.
Thanks, that's good to know they fit a dedicated unit, yeah I've looked at the timings of setting a charge cycle.Octopus fitted an all new dedicated metal trip and RCD box as part of my standard install. It’s a 45A unit. The 7p night rate is 23:30-05:30 or whenever you have an allocated charging slot car must be plugged in to activate your slots.
Octopus and other ‘big box’ installers will probably not want to be modifying that existing supply and reconnect your garage circuits.Thanks, that's good to know they fit a dedicated unit, yeah I've looked at the timings of setting a charge cycle.
