- 14 Apr 2014
- Hampshire
4800 Nm?! I hope you can get some REALLY good tyres. Or is it clever marketing speak where the wheel torque is substantially lower? I see the page also quotes 206…
Mental but I'm not a person with unlimited money so I guess I don't think like themAnd buyers will probably park it next to their GT3 and Defender OCTA.
Where are you buying 5mm cable ?yes you a right ... hadn't considered that, maybe cheaper to get the electricity board to install a cu in the garage rather than loose a 1kwh per night even just charging one car.
I showed you my workings which input data was wrong. ?
the 5mm2 was my recollection for one car @30m, but as said practically it would need to be a 6mm2 cable
206 is for the 80s car.4800 Nm?! I hope you can get some REALLY good tyres. Or is it clever marketing speak where the wheel torque is substantially lower? I see the page also quotes 206…
Probably been discussed, but also just had an email from Ovo and apparently Ohme will stop working from 15th July due to changes they've made. So for my dad, he'll be charging at whatever the normal rate is. 27p or something around there. Still cheaper than a tank of petrol but yeah, a bit frustrating. Going to see if he wants to change to Octopus or not.
Where’s 1kwh per night come from ?
Just that Ovo have made improvements or changes to their Charge Anytime tarriff and Ohme have not done anything to be compatible with it. So no more intelligent charging. If you have a car from a very small specific list, then Ovo say they can still work but use the car settings and not Ohme to get around the issue. My dad's is not on the list either.That’s crap have they said why ?
i really rate Octopus, I do not believe we would have many of the other companies offering such good tariffs as they do were it not for them competing with them.This is why you go with them and stick with them ignore OVO British gas tomato energy and other gimmicks
back of a vape packet - single car ie 32A would be 250W/hr cable loss .... suppose you typically charged it half the night 4 hours ie 28kw(100miles) that would be circa 1kwhr/8pWhere’s 1kwh per night come from ?
as rroff said 64A(2 cars)*9volts is circa 500W - didn't everyone repeat his mental arithmeticYour number was the 500W loss…
I suspect 4800 NM is the wheel torque. Tesla have played that game before too.
In that context it's nothing too crazy. An ID7 has over 4300 NM wheel torque in just the standard single motor version too.
