- 14 Jul 2005
- Birmingham
Yeah I left those bits sticking out with the intention of bolting joists together to extend out towards the opposite side there. A full cantilever wouldn't have been possible though I don't think, it's too far a distance compared to the supported distance, and there's still no beam on the far right.Cantilever but you have made it tricky now with how you have laid out the beams
You cuold sister up to the one by the right of the loft hatch and the one on the far left of your last photo
Somehow I need to sit a beam on the wall plate but the issue will be cutting a 45 degree angle reducing the strength at the bearing.
If I add an additional block of wood on top of the wall plate (blue) and then reinforce the cut joist end (red) with a triangular steel plate (green), does this strengthen the bearing end sufficiently? And also could I also bolt the joist to the existing rafters or somehow sister the rafter for extra support?
. **** doing any loft business in the current heat!
