Borderlands 4 (2025)
I’ll come out and shoot from the rooftops “THE PRE-SEQUEL IS MY FAVOURITE!”
I know us Borderlands fans are still using SHIFT codes so here's a big one from PAX East.
sfxjt-s3xs3-3t3jt-33btj-r33jj
This SHiFT Code unlocks 75 Golden Keys in multiple Gearbox games plus 20 Diamond Keys in Borderlands 3! Make sure to redeem in all qualifying Gearbox titles to get the most out of your rewards!
Thanks, I redeemed it for Borderlands 2 as I just started playing it for the first time.
What are the Golden Keys for?
Played BL1. Loved BL2. Over a thousand hours on it. Mastering Meele Zero was tough, real risk reward character. Loved Digistruct peak. Couldn't get into BL3.
Gibbed save editor was great also :p
Cheers!
Ah!
I rage quit Borderlands 3 when, even lowering the difficulty to easiest setting, I couldn’t beat Troy. Even watching multiple YouTube videos on how to do it I just could not defeat him.
I ******* hate boss levels and would happily have a skip option, with some derogatory achievement, for them in any game.
I think the people who have issues with Borderlands difficulty are just not farming. Borderlands is all about getting those elusive good weapons and building good skills trees. Really, all the bosses in 3 are very easy. You just need more POWER! There is nothing clever about them at all.
Half the problem with BL3 was that the "good" weapons weren't elusive at all and legendaries dropped far to frequently. I'm overjoyed to see they're fixing this in BL4.
As an example of how daft it gets, this is the result of a run on Slaughtershaft at Mayhem 11 with the Shlooter artifact:
IIRC the stats on those legendaries could vary though. The game became a bit like Diablo. Contrast to the first, where a mate and I both managed to play the game with underleveled 'normal' pistols.
I disagree.
Most of the legendaries are just variations of the same thing, and most of them aren't particularly good.
There are always a few guns in Borderlands that are leaps and bounds better than others. But you also need to the right stats with them, and the right level. Even given the high drop rate of 3, it was tedious to get the right gear.
I seem to remember that I got all of mine from keys because the drops, while many, were just useless.
Didnt know about the 4th one until it was advertised on Steam. Gameplay trailer looks good.
kinda put off some what with the EULA changes made advertised under the boarderlands 2 reviews. so on the back burnerat moment. doubt i'll be able to play it with current hadware any way untill a replacement machine comes through
Wow I think Borderlands 4 may be the first game to require minimum 8 core CPU to run like Ryzen 7, Ryzen 9, Core i7 and Core i9 CPUs. Ryzen 3, Ryzen 5, Core i3 and Core i5 with up to 6 cores will struggle to run Borderlands 4.
yer i defo cant run that at the moment..
it best run like a dream and with out any issues if it requires that level of cpu support, unless 2 or 3 of those cores are for bitcoin mining..
