Can't remember what car you have but a lot of cars won't work at more than 7kW anyway but 2.4 is quite slow and might be limited by the fuse so they don't give everyone loads of free leccyFirst drive into the office this morning, hooked it up to one of the 11kWh chargers just to see how it all works.
Came back an hour later and it had added...2.4kWh. Seems it doesn't quite work how I assumed![]()
Presumably the car has an 11kw onboard charger? If it’s only got a 7kw single phase charger it will only charge at 3.6kw on an 11kw charger which is 3 x 3.6kwFirst drive into the office this morning, hooked it up to one of the 11kWh chargers just to see how it all works.
After some research this morning it appears this is it, it's only got 7kw AC onboard. So all makes sense now (ish).Presumably the car has an 11kw onboard charger? If it’s only got a 7kw single phase charger it will only charge at 3.6kw on an 11kw charger which is 3 x 3.6kw
Seems a bit pointless to have 11kw 3 phase chargers surely? Very few cars are capable (some have them as an option, but does anyone actually take it?).Presumably the car has an 11kw onboard charger? If it’s only got a 7kw single phase charger it will only charge at 3.6kw on an 11kw charger which is 3 x 3.6kw
The vast majority of people are going to charge at home on a standard single phase 7kw charger, so that's all they'll ever need.
Uk grid is on a phase per street to balance to load typically. Also the reason most on street chargers are 7kW. Only businesses or people with swimming pools tend to have three phase.
You are right though. Most people don’t need 11kW at home. But it’s useful on the car if you find a destination charger that’s 11kW
Its way more common in EU
Ah that looks awesome! Don't often see the red. Makes a nice change from all the grey cars.Here we are then, drives nice https://photos.app.goo.gl/VwwLrFCNSc61mke37
Model Y - passed MOT with no advisory's on Friday. Can't believe it's 3 years old.
Can’t believe a ball joint didn’t fail eitherModel Y - passed MOT with no advisory's on Friday. Can't believe it's 3 years old.
I guess the 11kW vs 22kW thing is probably down to the simple fact 11kW is cheaper and easier to provide, people aren't typically expecting to fast charge from such chargers (if they want that, then 50kW+ DC is usually available anyway) so why bother with the added expense on either side of the equation for a relatively niche use case?
It only unravels a little when you get the combo of an 11kW charger and a car without 11kW capability - judging by the available filters on EV Database, the vast majority of EV models do actually seem to be 11kW (or better) compatible, accounting for 893 models of the 978 they have on their list.
Stuff that only has 7kW onboard is relatively uncommon (and they seem to be older or more value oriented cars).
How many miles does it have?
Mine had advisories for rear upper control arms which were replaced recently under warranty. Kinda hoping the front ones go within the next 6000 miles…
