- 25 Nov 2005
Using Chatgpt makes you less cognitive at least when writing essays although I don't see how the same couldn't translate to other things you use Chatgpt to do the "thinking" for you
AI can be a massive time saver. The issue isn't the question of whether it saves time or makes people more productive, its whether it completely removes the thinking part from many peoples actions. People who are already experts in an area can usually use it as a tool to accelerate their work. People with little experience will use it to completely replace the requirement for understanding and certainly in my field (programming) you can get into huge messes without realising it.
I do think it’s a good replacement for a Google search. It’s feels better that it’s conversational and it’s basically just consolidating several searches, which is what you’d be doing manually.I must be honest, it's made working on my motorcycle a hell of a lot easier. Rather than spend hours trawling the web for very niche and very specific information, I ask ChatGPT and it answers instantly. I can then double check the sources and it's generally always right.
Yeah pretty much this. I'm a programmer too and it's a massive help to my. productivity. I'll get it to generate DTO's for me because that's just mundane to do and boilerplate stuff. Of course there are people out there saying "I have zero experiance and built this iOS TODO app with GPT - programmers being replaced?!"
Sure buddy, now try add a new feature or fix a bug in that app....
Just checked. Tried different words. Always says it's Trump.
