Yes, it has both PBP and PIP. You can select how to arrange two separate inputs - side-by-side 50/50, 75/25, as well as windowed overlayed.Does the AW3225QF have PBP mode? Can anyone confirm?
How's your experience been with PBP so far?Yes, it has both PBP and PIP. You can select how to arrange two separate inputs - side-by-side 50/50, 75/25, as well as windowed overlayed.
I tried it out of curiosity - it works. Beyond that I have no use for it. I do have two machines connected to my AW3225QF and I just switch on the monitor inputs altogether if I need to switch between them.How's your experience been with PBP so far?
The latest KB5058499 update is available to all Windows 11 users right now if you’ve enabled the “get the latest updates as soon as they’re available” option in Windows Update. Once it’s installed, you can now toggle the ability to stream HDR video option even when HDR is disabled in Windows, allowing you to view HDR content from apps like Netflix or websites like YouTube without having to enable HDR throughout Windows.
Can't believe it's taken them this long! Installing the update now and will be testing on YouTube ASAPGood news:
Windows 11 gets some much-needed HDR improvements
Windows still needs more HDR improvements, thoughwww.theverge.com
Tried updating, just sits there initializingNew firmware out, anyone tried it yet?
Tried with those as well, same issue so uninstalled and blocked againSame issue on my machine, tried it connected to different USB ports on my board and wont get past initializing. Do you need the alienware drivers installed as I have them blocked?
Tried with those as well, same issue so u installed and blocked again
I've tried doing the update on my laptop as well and same issue just sticks on initializing forever.
Update - finally worked for no apparent reason after I plugged the USB back into my desktop PC.
It retained the settings on mine.Does the firmware update retain monitor settings?
